Hallo G’Day s Zetor 5745
AusZetor
AusZetor
Pemberton Western Australia, Australien
Chris
Zetor 5745
Hello everyone, thank you for taking the time to accept me as a member of your great forum!
I have recently purchased a Zetor 5745, and I will be using the old girl to launch and retrieve my fishing boat at my local beach and fishing shack. I hope to find answers on this forum to my questions about my Zetor as this tractor is very new to me. I have read many wonderful facts surrounding the history of Zetor and I am glad that I have found myself a wonderful little tractor blessed with some great Eastern European engineering. I hope to make some good forum friends here, thanks again.
Chris
a.k.a AusZetor
Hallo und :welcome2Chris hier im Zetorforum.
Mit dem Zetor hat man einen Zuverlässigen Traktor wenn man immer mal wieder ein bisschen Zeit in Wartung und Pflege investiert.
Hello and :welcome2Chris here in Zetorforum.
With the Zetor you have a reliable tractor if you spend a bit of time in maintenance and care.
Hello and :welcome Chris.
We talked about a little bit on facebook just bevor. Do you find now the paint RAL code infos you need?
Greatings of Sveden:freu
Its permitted now. ;) See my infos in your facebook thread. :)
It doesnt give a RAL code "2240" - what you mean is a color code of one manufakturer of paints (in this case its Kramp).
2240 AND 2002 are not the real original colors - both are neear by - but not the original.
Zetor uses the older CSN color code system that contains other color shadows as the RAL color system can build up.
The same with RAL 1020 - its near by, but not real 100% original ;)
Also - all known color codes you can find here: Farben und Lacke - Zetor Original, RAL, Tipps, Bezugsquellen (https://www.zetor-forum.de/ressourcen/farben-und-lacke-zetor-original-ral-tipps-bezugsquellen.25/)
Es gibt keinen RAL-Code "2240" - was Sie meinen, ist ein Farbcode eines Lackherstellers/-lieferanten (in dem Fall ist es Kramp).
2240 UND 2002 sind auch nicht die echten Originalfarben - beide sind nahe dran - aber eben nicht das Original.
Zetor verwendet das ältere CSN-Farbcodesystem, das andere Farbschattierungen enthält, als das RAL-Farbsystem für Lacke abbildet.
Das gleiche bei RAL 1020 - es ist nah dran, aber nicht wirklich 100% original ;)
Außerdem - alle bekannten Farbcodes findest du hier: Farben und Lacke - Zetor Original, RAL, Tipps, Bezugsquellen (https://www.zetor-forum.de/ressourcen/farben-und-lacke-zetor-original-ral-tipps-bezugsquellen.25/)
7K
UTB 550 S
