Try another (for me personaly the better way) way:
Open the thread you want to read and (with Chrome Browser) make a right click and choose "translate to ..." what ever you want. That works on all sites.
If I try to use translated link (red circle in pucture), this
forum will block me.
I have tried this 4 different internet connections, 1 laptop pc and 2 different mobile phones. And it is same thing on every device and connection.
When you try it first time, you will be blocked for about 1 day. 3rd try will block it longer, example IP from my working place have now been blocked several days
Yes - that's the normal behavior from our anti
spam mechanism on server side.
The way you use it, I think you use a proxy from Google translator - and this behavior is the detected as problematic and will be blocked.
I don't understand at the moment the complete way Google do this, so I have actuel no time to find out what exactly the problem in this point is. Please try my hint above, I think that should work.
Otherwise you can switch the
forum language to English at the very bottom left side:
... to have the most things in englisch language. The rest you can translate by right click as I mentored you above.
But ... yes - this forum is fore grounding set to be used from people with German language. The native englisch version will come back later with the good old zetorworld.com forum - but the former used software is very old and the upgrade/switch to a actual system needs many hand work and time, more as I thinked.
And so it needs a little bit to be ready.
