Hello (David´s Zetor´s)
  • Ersteller des Themas duttnut
Zitat von Joachim:
Hello David,
yes - i like. :D We (the forum community) have made a calendar for 2014 with pictures from Zetor tractors... A picture from you in the next calendar 2015? ;) :)
Yes, if you like any of my pictures for a calender then feel free to use them :)
I plan to get all my Zetors together in next couple of weeks to take a big picture of them all.
Hello David,
for a calendar: min 2550x1920 pixel resolution ;)
Hi Dave,
I'm curious and looking forward to see your Zetor Fleet on one pic :)
Here's some pictures of my Zetor 3011 which I bought a few weeks ago.
Hello David,
nice - but the seemingly neat oils below the exhaust. :shock: And no center caps ... :denk3
Hi David,
yea, the missing wheel hubs are going to speed up to kill your wheel bearings. Care about it. :)
Can you go on puplic roads without headlamps? :shock:
I mean i see a Registration plate, therefor.
Zitat von Joachim:
Hello David,
Yes the engine is going to need some work to stop that oil coming out of the exhaust, and I have the new centre caps for the front. It seems like they stick out a lot and so will catch on things like gate posts, doorways. The reason it did not have them I think.
Zitat von 3011Major:
Hi David,
I have to clean out and grease the wheel bearings, It is my next job.
I then will remove the cyilinder heads, and look for any problems.
In the UK there is a daytime only license (ministry of transport test "MOT") for vehicles that have no lights. A tractor doesn't need any type of license anyway. Many tractors can be in quite a poor condition and still travel on the roads.
I can use hand signals on the road, but not drive at night. The tractor is insured properly.
Hi,
I have been doing some work on my tractors,
I have fitted new liners and pistons to my 3011, also new connecting rods, new big end bearing shells.
I have also fitted hub caps!
I have had a problem with my 6718 for a long time, the lift arms going down on their own when they are lifting something heavy.
Today I have removed the top of the axle to look at the seals.
This was all that was left of the seal,
I have also bought an Ursus C-385 which is in very good condition mechanically but looks untidy.
Hello David,
the black NBR seals are bad - mount better the blue PUR seals for a longer liftime. :like
Your "new" Ursus ... is this maschine similar to a original Zeor 8011?
Yes very similar. As far as I can tell the only difference being that the doors open the other way and the headlights.
David5011
David5011
Kenni
AusZetor
David5011
UTB 550 S
RedSkidder
