Frage Zetor 5011 - shifting problems
  • Ersteller des Themas Woodman
Woodman
Woodman
UK
Harris
Zetor 5011
I have got a problem , I can select a gear but when I let the Clutch out the tractor does not move forward or reverse, can anyone help please
Alles in Englisch, aber evtl. mit dem Google Übersetzer?
Ist denn der Gruppenwahlhebel auf kleine Gruppe (Schildkröte) oder große Gruppe (Hase) gestellt?
Wenn dieser im Leerlauf ist passier nämlich auch nichts.....
Everything in English, but possibly with the Google translator?
Is the group selector set to a small group (turtle) or a large group (rabbit)?
If this is idle nothing happens .....
Good morning , All the selectors are in correct positions , we have removed the top cover under the seat and selected 1st gear and moved it forwards and backwards and everything is all moving as it should but the engine is turning over while in 1st gear
Please help
Hello.
I think you have to remove the gearbox cover and take a look (and pics please ;) ) from the gear shift rod system. It can be, there is the one broken witch shift the group gear from rabbit to turtle.
Greetings to UK :)
Ich denke du solltes den Getriebedeckel abbauen und einen Blick (und Fotos) hinein werfen. Es kann sein, das die Schaltgabel der Gruppenschaltung (Hase / Schildkröte) gebrochen oder verbogen ist.
Grüße nach UK
Hi everyone
I've took some pictures of the zetor 5011 gearbox and everything looks okay, but the pro shaft and the clutch shaft have a lot of play
CAZetor
6K
Zetor5011
Markus zetor 5011
Markus zetor 5011
