Zetor 5011 Romania
  • Ersteller des Themas Petrut28
Petrut28
România
Albu Petru
zetor 5011
fiat 450dt
Hello! I recently purchased a 5011 1982 zetor.I like it very much but I have a little work with it. I need two new wings on the back, cover protection board, some electrical stuff.Can you recommend an online store where i can order parts? and how much it would cost to deliver to Romania. And i have a little problem,the tractor does not release any gases on the exhaust but when it heats up, it removes, release gases on the "oil breather"(I don't know exactly what it's called),i think the rings on a piston are worn out
Hello and welcome. :)
And i have a little problem, the tractor does not release any gases on the exhaust but when it heats up, it removes, release gases on the "oil breather"(I don't know exactly what it's called),i think the rings on a piston are worn out
Yes I think its a piston problem - the only way to clarify is to demount the cylinder heads and take a look at.
For parts dealer near to your home, simply use a web search to "Zetor parts" and add the needed country like "de" for Germany or "cz" for Czech or what ever your favor will be.
As I can see at you photos, you need a lot of work with rusty parts at your Zetor... ;)
Markus zetor 5011
Markus zetor 5011
Sid
Wim Wuyts
Charly
