E
EgilF
Von 14 bis 17 Jahren habe ich in der Schule Deutsch gelernt, aber es ist ungefähr 40 Jahre her und ich habe vieles vergessen. Es ist ein gutes Training für mich, in diesem Forum zu lesen, aber ich habe probleme, auf Deutsch zu schreiben. Ich hoffe, Sie verzeihen mir, dass ich auf Englisch schreibe.
My 5745 has blue smoke and I was advised to drive it hard so that old soot and coke could be burned away. But I did not get to try it completely, because the engine power was weaker than it should be. After reading about the injection nozzle here, I tested them and turned off the diesel supply on one nozzle at a time. On three there was a noticeable difference in the engine speed, but on the 4th there was no change. So I changed the injection nozzle. Then I see that in three of the cylinders there is a mixture of oil and water around the nozzle. The gray mass is a sign of oil and water. (Picture). I also found that it leaked diesel from one - where I made a red ring.
The engine oil does not have this gray color, it is thin (maybe there is diesel in it? I do not think it smells like diesel from the oil, but do not know for sure.). I changed the cylinder head gasket (and oil) this summer, and have driven less than 10 hours since then. Before I replaced the head gasket, there was pressure in the cooling water so that it bubbled heavily in the radiator and the water was thrown out. Can the oil and water mixture be there from before I changed the cylinder head? Could it be the Injector holder bush or the sealing washer that leaks?
